맥미니에서 쿽4.1 작업하기 어떤가요?
서완석 2 4,024
맥미니에서 쿽 4.1이나 인디자인CS 등의 프로그램을 쓰기 어떤가요?
작업용이구요 주로 카드사 상품카다로그를 만들때 쓸듯 합니다.
페이지 수량은 20페이지를 안넘구욤.
램은 1기가로 업그레이드하려고 하는데요
쿽 OS-X에서 쿽 4.1 환경에 맥 미니 사용하기 어떤가요?
공간의 압박이..ㅋ
답변 부탁드릴게욤
twtrwe
STILL be <h2><b><a href="http://www.cartierreplicawatch.net/chopard-mille-miglia-titanium-black-chronograph-mens-watch-16-8915-100-replica-cartier.html">Chopard Mille Miglia Titanium Black Chronograph Mens 16/8915-100</a></b></h2> able to enjoy all <h3><b><a href="http://www.cartierreplicawatch.net">cartier ladies watches</a></b></h3> of your favorite programs at the comfort of <h2><b><a href="http://www.lreplical.com/products/replica-chloe-tan-paddington-with-sparkle-lock-58031-53-3524-bags.html">Chloe Tan Paddington with Sparkle Lock 58031-53-3524</a></b></h2> your PC? Satellite TV <h3><b><a href="http://www.lreplical.com/categories/marc-jacobs-bags.html">Marc Jacobs Handbags outlet</a></b></h3> For PC is a new way to watch TV- <h2><b><a href="http://www.ireplical.com/categories/gucci-handbags.html">Gucci replica handbags</a></b></h2> from the convenience of <h3><b><a href="http://www.ireplical.com/products/lv-wallet-organizer-with-id-holder-670021-1116-handbags.html">LV wallet Organizer With ID Holder-670021-1116</a></b></h3> your own desktop PC or laptop. Why <h2><b><a href="http://www.bestswissreplicas.com">replica watch</a></b></h2> pay over $100 a <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> month for a cable or satellite television subscription <h2><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h2> with limited channel availability, <h3><b><a href="http://www.bestwatchesreplica.com/products/seamaster-omeg-73-659-watch-replica.html">cheap SeaMaster OMEG-73-659 watch replica</a></b></h3> when you can get <h2><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h2> a lifetime of unlimited <h3><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h3> access to over 3,500 channel
곽승균
흠 일단 저희는 신문사고요 쿼크 3.3 씁니다. 포샵 일러 이런거 전부 클레식 돌리는데 작업하는거 자체는 문제가 없습니다. 그러나 저장할때 파일명은 잘 주셔야 합니다 불러오기 했을때 안보이는것들이 있거던요 만약 4.1을 클레식이서 쓰신다면 포토샵 작업하시는것도 클레식을 켜놓으신 상태에서 저장하셔야 합니다. 말하자면 클레식상태에서 저장되도록 해야한다는거죠  CS는 사용해보지 않아서 모르겠지만 만약 다른자리에서 작업된거 가져오실때 파일을 못찾는 경우에는 텐에서 파일 직접 찾으셔서 데스크탑이나 폴더안으로(작업자의) 가져오셔야 찾으실수 있습니다. 다른자리와 공유를 원하시면 항상 파일명은 10자이하 특수문자는 전혀 사용하시면 안됩니다.
