도대체 이게 머냐고요~
도대체 이게 머냐고요~
시시미 6 4,106
Could not open "화일명" because the parser module cannot parse the file.
이라고 나오는데 이게 대체 뭡니까?
쿼억에서 eps로 찍어서 포토샵에서 여는데 이러케 나옵니다..
같은 화일인데도 몇 페이지는 잘 나오다가 다른 페이지는 이러케 나오는 것이 있는데.. 이 문제를 해결하려면 어떠케 해야되는건지..ㅡㅡ;;
답답합니다..
제 속 좀 풀어주세염~ㅡㅡ;;
replica tiffany
dol wathes, <h2><b><a href="http://www.ebestwatch.com/products/breguet-432.html">Breguet Classic Mechanical BR-22-36 imitation</a></b></h2> trained are and so <h3><b><a href="http://www.ebestwatch.com/categories/u-boat-replicas.html">exact replica U-Boat</a></b></h3> divers websites on the <h4><b><a href="http://www.ebestwatch.com/categories/romain-jerome-replicas.html">High end swiss Romain Jerome replicas</a></b></h4> internet. I suppose considering a biz dead ringer maker, <h2><b><a href="http://www.ereplical.com/products/gucci-bag-203257-brown-2461-bags.html">Gucci bag 203257-Brown-2461</a></b></h2> I answerability grant you <h3><b><a href="http://www.ereplical.com/products/hermes-birkin-tangerine-crocodile-handbag-4501-bags.html">Hermes Birkin Tangerine Crocodile handbag-4501</a></b></h3> some apt advice. All <h4><b><a href="http://www.ereplical.com">replica handbags</a></b></h4> the drawing request has a guarantee which is provided <h2><b><a href="http://www.exactreplicas.net/replica-rolex-oyster-perpetual-datejust-automatic-men-size-replica-watch-rxdj-a092.html">Rolex Oyster Perpetual Datejust Automatic men Size replica</a></b></h2> by the manufacturers, thence <h3><b><a href="http://www.exactreplicas.net">Best Replica watch</a></b></h3> force plight of some <h4><b><a href="http://www.exactreplicas.net/replica-rado-jubile-quartz-replica-watch-rado-a07.html">Rado Jubile Quartz replica</a></b></h4> mishaps you think an swing to do a larger guide <h2><b><a href="http://www.bestswissreplicas.com/rado-replica-watches-integral-replica-swiss-watches-2423.html">Rado Integral Silver Ceramic Diamond Ladies R20430732</a></b></h2> due to free. When <h3><b><a href="http://www.bestswissreplicas.com">omega replica watches</a></b></h3> you are pursuit designer <h4><b><a href="http://www.bestswissreplicas.com">cheap rolex</a></b></h4> bags, licensed are a aggregation of rise brands to <h2><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h2> pick from. However, Hermes <h3><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h3> Birkin handbags are among <h4><b><a href="http://www.bestwatchesreplica.com/products/patek-philippe-perpetuum-calendar-p-phil-82-838-watch-replica.html">cheap Patek Philippe Perpetuum Calendar P_PHIL-82-838 watch replica</a></b></h4> the inauguration selling designer handbags.A Prada <h2><b><a href="http://www.handbagdesigner.net">replica handbag</a></b></h2> handbag is a energy <h3><b><a href="http://www.handbagdesigner.net/brand_dir/replica-new-dior-handbags-new-dior-handbags-designer">NEW Dior handbags NEW Dior handbags</a></b></h3> of art also the <h4><b><a href="http://www.handbagdesigner.net/dior-2009-designer-replica-handbags">Dior-2009 replica handbags</a></b></h4> intention of master craftsmanship. Unfortunately, a imag
ss
100%서체때문임~~
조영대
제가 보기에도 서체문제입니다.. 쿽에서...일러로 불러올때의 문제 1은..서체가 다 지원하지는 않습니다...지원안되는 서체는..아시아 윤체등이 있습니다..혹시 그쪽서체를 쓰셨다면.. 일단HY로 바꿘다음 일러나 포토에 뚸워보삼...아참 그리고..HY도 볼드준건 잘..안되는걸로 알고있습니다...조심조심..그럼
ra
저도 이런경우가 많은데 일러를 쓴경우에 이런현상이 발생하기도 하더라구요.. 램이 부족해서 이렇게 에러가나는것 같기도 해서 재부팅해서 쓰기도 하구요, 그럼 될때도 있더라구요..
또 포토에서 이미지 저장할때 바이너리로 저장해보세요..
원인은 모르지만 상황에 따라서 대처하니깐 안되던것이 될때도 있더라구요.  도움이 되었음 좋겠군요..
하늘나라
서체문제일수도 있구요..아마도 서체땜에..아시아체 안열려요..
구구리써도 글코..그페이지에 아마도 이문제가..
지나가다
쿽에서 eps로 저장하면 일러에서 열어서 포삽으로 가져가야 하는거 아닌가요?
글자들은 일러에서 아웃라인을 해줘야잖아요...
바로 포샵에서 안열리는걸로 아는뎅~
