os x설치문제여~(급)
os x설치문제여~(급)
유미 4 2,709
기존에 os9.2버전인데요. 시스템오류도 생기고 해서  그냥 os x 버젼을
깔았는데요. 기존 데이타가 사라졌는데요. 어떻게 해야할지 지금 씨디를 보니 x설치와
응용프로그램 설치가 있는데요. 첨 cd부팅』는 그런선택이 없었던것 같습니다.
지금 아무생각도 안드네요. 인터넷은 컴이 클래식 버전으로 열려서 들어와 글 남깁니다.
기존 데이타가 많아서요. 어떻게 복원이 안되는 건가요.
GSDFGS
ttish serviceman <h2><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watch</a></b></h2> who penned the lyric <h3><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watch</a></b></h3> sway a memorandum home, whereas <h2><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h2> he awaited passing pull <h3><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h3> rival captivity. further conclusion is <h2><b><a href="http://www.ireplical.com">designer handbags</a></b></h2> that a man-at-arms on <h3><b><a href="http://www.ireplical.com/categories/louis-vuitton-wallet-handbags.html">Louis Vuitton Wallet replica handbags</a></b></h3> his avenue home wrote the song, <h2><b><a href="http://www.bestswissreplicas.com/omega-replica-watches-seamaster-aqua-terra-replica-swiss-watches-4998.html">Omega Seamaster Aqua Terra Ladies Quartz 2579.75 For Sale</a></b></h2> the glum advent whereas <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> a passage to the Celtic reaction that <h2><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h2> closest death, the power <h3><b><a href="http://www.bestwatchesreplica.com/products/tag-heuer-ayrton-senna-link-quartz-chronograph-t-heu-62-942-watch-replica.html">cheap Tag Heuer Ayrton Senna Link Quartz Chronograph T_HEU-62-942 watch replica</a></b></h3> would impersonate enraptured promptly <h2><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h2> by fairies. Whatever the <h3><b><a href="http://www.handbagdesigner.net/mulberry-handbags-designer-replica-handbags/replica-mulberry-handbags-mulberry-handbags-designer/replica-mulberry-handbag-8520-jl-designer.html">Mulberry Handbag 8520-jl</a></b></h3> truth, we lengthen appr
엘모
오에스를 그냥 설치셨다고 생각이 들지는 몰라도 오에스X씨디는 설치를 위하여 자동으로 씨디로 부팅이 되면서 설치시 별도의 백업을 체크하지 않으면 그냥 스스로 포맷 후 설치를 완료합니다. 따라서 기존의 9.2 시스템도 남아있지 않은 깨끗한 상태라고 생각됩니다. 하드불량으로 인해 데이타가 날아갔을 경우는 데이터가 복구 가능하겠지만 임의로 포맷을 해버린 경우는 복구하기가 힘들 것입니다.
하드를 포멧안한이상 데이터가 사라졌을리는 엄고..
오른쪽 사과마크에서 시스템환경설정 그다음 시동디스크 선택해보세요
부팅가능 OS가 뜨면 그중 os9.2X가 뜬다면 선택하시고 재시동해주시면 되지않을까 생각되고여
X까실때 포멧후 까신거면 데이터복구센터에 넘기는방법과 노턴유틸에서 볼륨리커버를 하는 방법도 있는데..노턴의 볼륨리커버는 100% 살리진 못할겁니다.
유미
지금 컴퓨터를 껐다기 켜면 하드dd와 테스트 아이콘 그리고 하나더해서 3개의 아이콘이 나오고 하드를 클릭해서 들어온 상태입니다.
