외장하드 맥호환용 추천
외장하드 맥호환용 추천
유제이 12 8,738
제가 맥을쓰는대
외장 괜찮은것 추천부탁드려요
어떤게 좋을까요?
한 400~500gb 정도요
GSFDG
are. <h2><b><a href="http://www.cartierreplicawatch.net/replica-cartier-ballon-bleu-de-cartier-cartier.html">Replica Cartier Ballon Bleu de Cartier Watches</a></b></h2> ? Temptation. considering mentioned <h3><b><a href="http://www.cartierreplicawatch.net">Best Cartier Watches</a></b></h3> previously, relapse is <h2><b><a href="http://www.lreplical.com/categories/thomaswylde-bags.html">Thomaswylde Handbags outlet</a></b></h2> built significance the Stages <h3><b><a href="http://www.lreplical.com/products/replica-designer-replica-louis-vuitton-handbag-m9278847435-931-bags.html">Designer Louis Vuitton Handbag M9278847435-931</a></b></h3> of change draft through a lively <h2><b><a href="http://www.ireplical.com/categories/prada-handbags.html">Prada replica handbags</a></b></h2> type that modify is <h3><b><a href="http://www.ireplical.com">designer handbags</a></b></h3> hard and that a accumulation of cravings, emotional <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> stress, again extroverted situations <h3><b><a href="http://www.bestswissreplicas.com">replica watch</a></b></h3> or prompts blame <h2><b><a href="http://www.bestwatchesreplica.com/products/cartier-ballon-bleu-tourbillon-cart-6-311-watch-replica.html">cheap Cartier Ballon Bleu Tourbillon CART-6-311 watch replica</a></b></h2> begin us bear to <h3><b><a href="http://www.bestwatchesreplica.com/products/rolex-oyster-perpetual-rlx-19-1060-watch-replica.html">cheap Rolex Oyster Perpetual RLX-19-1060 watch replica</a></b></h3> invalid habits. Instead of bad eye <h2><b><a href="http://www.handbagdesigner.net">designer handbags</a></b></h2> these events seeing failures, <h3><b><a href="http://www.handbagdesigner.net">cheap handbags</a></b></h3> however, the study asks
gfsdf
s. The <h2><b><a href="http://www.cartierreplicawatch.net">cartier ladies watches</a></b></h2> companies that provide snacks <h3><b><a href="http://www.cartierreplicawatch.net/movado-juro-mens-watch-0605023-replica-cartier.html">Movado Juro Mens 0605023 imitations</a></b></h3> may also provide other individually packaged <h2><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h2> items like jams and <h3><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h3> jellies, butter pats, coffee <h2><b><a href="http://www.ireplical.com">replica louis vuitton handbags</a></b></h2> creamers and cream cheese. <h3><b><a href="http://www.ireplical.com">replica designer handbags</a></b></h3> Many offices find that providing <h2><b><a href="http://www.bestswissreplicas.com/replica-mont-blanc-watches-swiss.html">Mont Blanc</a></b></h2> these in sanitary individual <h3><b><a href="http://www.bestswissreplicas.com">breitling replica watches</a></b></h3> packages cuts down on waste <h2><b><a href="http://www.bestwatchesreplica.com/products/breitling-bentley-edition-automatic-breit-206-101-watch-replica.html">cheap Breitling Bentley Edition Automatic BREIT-206-101 watch replica</a></b></h2> and is more economical <h3><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h3> than buying them at the supermarket. Supplies <h2><b><a href="http://www.handbagdesigner.net/brand_dir/replica-chanel-handbags-hysteria-collection-designer">Chanel handbags Hysteria Collection Designer Handbags</a></b></h2> and Equipment What happens <h3><b><a href="http://www.handbagdesigner.net/brand_dir/replica-louis-vuitton-wallets-agendas-designer">Louis Vuitton Wallets Agendas</a></b></h3> if your coffee c
네~ 유제이님께서도 즐거운 설명절을 보내시기 바랍니다. ^^
유제이
설명 감사합니다
많은 도움이 되었어요
설날 잘보내세요 ㅎㅎㅎ
매킨토시 대리점이 아니라면 맥용 포맷을 지원받기에는 어려움이 있을 것입니다.
OS X을 사용 중이라면 디스크 유틸리티 프로그램에서 지우기로 들어가 Mac OS 확장 저널링 혹은 Mac OS 확장 포맷으로 초기화를 하시면 됩니다.
만약 OS 9을 사용중이라면, 별도의 포맷 유틸리티를 다운받아 사용을 하셔야 합니다.
http://www.iplace.co.kr/bbs/zboard.php?id=library&page=1&sn1=&divpage=1&category=3&sn=off&ss=on&sc=on&select_arrange=headnum&desc=asc&no=24
Windows 호환으로 사용을 하는 것은 용량 손실, 안정성 등의 문제로 맥전용으로 사용을 하실 것을 권합니다.
http://iplace.co.kr
맥대리점에서 구입을 하는 경우에는 포맷을 해주지만 일단 컴퓨터 관련 업체에서 구입을 하시면 본인이 직접 포맷을 하시면 됩니다.
OS X에서는 디스크유틸리티로 하시면 되고요.
유제이
아!!! 감샤해요
마지막으로 한번만 더 물어볼께요
제가 무지해서요
그럼 케이스는 새로텍 3.5는..W-31UF
안에 하드는 시게이트3.5로 살껀대 내장형(?)으로 따로사서 조립해서 쓰면 되겠죠?
그리고 맥이랑 피씨 호환용보다 그냥 맥용으로만 쓰는게 바이러스문제도 안전하겠죠? 포맷은 판매처에서 해주는건가요?
G4를 사용하시는 경우에는 파이어와이어(IEEE1394)포트가 있는 외장케이스를 사용하셔야 되고요.
하드는 시게이트 하드를 추천드리고 싶네요.
새로텍 외장케이스가 좋고요.
3.5"는 W-31UF로 하시고 2.5는 254UF2로 하세요.
emoticon_096 히타치보다는 씨게이트나 웨스턴디지탈 하드로 하세요.
(개인적으로는 요즘은 웨스턴디지탈하드가 괜찮은듯 합니다)
유제이
감사합니다
골랐는대요
새로텍3.5 i-stor F3b + 1Tb sata2 하드장착
(usb2.0 + 2-sata + 1394b 트리플콤보)
근대 장착된 하드가 히타치72rpm, 16mb버퍼 라는대요
이 하드도 괜찮을까요??
emoticon_096  케이스는 새로텍 제품이 맥에서 가장 무난합니다.
가급적 콤보형(USB2.0+ 파이어와이어 포트)으로 구매를하세요.
W-31USF(3.5" 콤보케이스)--->1394a+USB2.0+eSATA포트가 있는 외장케이스
W-31USF(3.5" 콤보케이스)--->1394a+USB2.0포트가 있는 외장케이스
FHD-254UF2 (2.5" 콤보케이스) --->1394a+USB2.0 포트가 있는 외장케이스입니다.
WIZPLAT W-31UF(3.5" 콤보케이스) --->WIZPLAT W-31UF는 1394a+USB2.0 포트가 있는 외장케이스
외장케이스는 새로텍에서나오는 제품으로 1394/USB지원되는 콤보케이스(W-31UF)로하시고, 내장하드는 WD나 시게이트로 구입해서 사용하시면 무난합니다.
