일러스트에서 C/M/Y/K값이 소수점으로...
선풍기 꺼내고 반팔 입어야 되겠어요~
정휘형
그래픽
4
5,233
2007.05.16 13:37
되는 이유는 멀까요?
스포이드로 찍지도 않았고..
손수 수작업으로 숫자를 입력했건만..
이 넘의 일러가..뗵~!
소수점으로 변환되는 이유와..
고칠수 있는 방법 아시는 분 도움 바랍니다!
여러분 행복한 오후되세욤~! ^^
replica watches
2010.04.08 16:08
ca watches <h2><b><a href="
http://www.omegareplicawatch.net/omega-seamaster-aqua-terra-150m-co-axial-midsize-watch-2504-50-replica.html"
>Omega Seamaster Aqua Terra 150M Co-Axial Midsize 2504.50 outlet</a></b></h2> like rolex, breitling,cartier, Louis <h3><b><a href="
http://www.omegareplicawatch.net"
>omega replica watches</a></b></h3> Vuitton repl <h4><b><a href="
http://www.omegareplicawatch.net/breitling-aeromarine-superocean-steelfish-x-plus-steel-mens-watch-a1739010-g5-894a-replica.html"
>Breitling Aeromarine Superocean Steelfish X-Plus Steel Mens A1739010-G5-894A outlet</a></b></h4> ica watch <h2><b><a href="
http://www.onreplicas.com"
>knockoffs handbags</a></b></h2> etc. All of the <h3><b><a href="
>fake handbag</a></b></h3> watches are crafted to <h4><b><a href="
>replica handbags</a></b></h4> meet the exact specifications <h2><b><a href="
http://www.handbagsfake.com/fake-versace-bags"
>qulity fake Versace handbags</a></b></h2> of the original designs, <h3><b><a href="
http://www.handbagsfake.com"
>Louis Vuitton fake handbags</a></b></h3> we not only ensu <h4><b><a href="
>fake handbags</a></b></h4> re the <h2><b><a href="
http://www.bestswissreplicas.com/replica-patek-philippe-watches-swiss.html"
>Patek Philippe</a></b></h2> replica watches look like <h3><b><a href="
http://www.bestswissreplicas.com/louis-vuitton-replica-watches-louis-vuitton-replica-swiss-watches-7096.html"
>Louis Vuitton Tambour elegants Ladies Tambour LV064</a></b></h3> the originals but also <h4><b><a href="
http://www.bestswissreplicas.com"
>designer replica watches</a></b></h4> the weight and <h2><b><a href="
http://www.bestwatchesreplica.com/categories/hublot-watches-replica.html"
>cheap Hublot watches</a></b></h2> dimensions are measured to <h3><b><a href="
http://www.bestwatchesreplica.com"
>watch replica</a></b></h3> be as accurate as <h4><b><a href="
>watches replica</a></b></h4> possible. Watchcopiez.com <h2><b><a href="
http://www.cartierreplicawatch.net/jacob-co-unisex-watch-jc8-2-replica-cartier.html"
>Jacob & Co. Unisex JC8-2</a></b></h2> only worked with the <h3><b><a href="
http://www.cartierreplicawatch.net"
>Replica Cartier Watches</a></b></h3> reliable and fine <h4><b><a href="
>Cartier Replica Watch</a></b></h4>
ca watches <h2><b><a href="http://www.omegareplicawatch.net/omega-seamaster-aqua-terra-150m-co-axial-midsize-watch-2504-50-replica.html">Omega Seamaster Aqua Terra 150M Co-Axial Midsize 2504.50 outlet</a></b></h2> like rolex, breitling,cartier, Louis <h3><b><a href="http://www.omegareplicawatch.net">omega replica watches</a></b></h3> Vuitton repl <h4><b><a href="http://www.omegareplicawatch.net/breitling-aeromarine-superocean-steelfish-x-plus-steel-mens-watch-a1739010-g5-894a-replica.html">Breitling Aeromarine Superocean Steelfish X-Plus Steel Mens A1739010-G5-894A outlet</a></b></h4> ica watch <h2><b><a href="http://www.onreplicas.com">knockoffs handbags</a></b></h2> etc. All of the <h3><b><a href="http://www.onreplicas.com">fake handbag</a></b></h3> watches are crafted to <h4><b><a href="http://www.onreplicas.com">replica handbags</a></b></h4> meet the exact specifications <h2><b><a href="http://www.handbagsfake.com/fake-versace-bags">qulity fake Versace handbags</a></b></h2> of the original designs, <h3><b><a href="http://www.handbagsfake.com">Louis Vuitton fake handbags</a></b></h3> we not only ensu <h4><b><a href="http://www.handbagsfake.com">fake handbags</a></b></h4> re the <h2><b><a href="http://www.bestswissreplicas.com/replica-patek-philippe-watches-swiss.html">Patek Philippe</a></b></h2> replica watches look like <h3><b><a href="http://www.bestswissreplicas.com/louis-vuitton-replica-watches-louis-vuitton-replica-swiss-watches-7096.html">Louis Vuitton Tambour elegants Ladies Tambour LV064</a></b></h3> the originals but also <h4><b><a href="http://www.bestswissreplicas.com">designer replica watches</a></b></h4> the weight and <h2><b><a href="http://www.bestwatchesreplica.com/categories/hublot-watches-replica.html">cheap Hublot watches</a></b></h2> dimensions are measured to <h3><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h3> be as accurate as <h4><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h4> possible. Watchcopiez.com <h2><b><a href="http://www.cartierreplicawatch.net/jacob-co-unisex-watch-jc8-2-replica-cartier.html">Jacob & Co. Unisex JC8-2</a></b></h2> only worked with the <h3><b><a href="http://www.cartierreplicawatch.net">Replica Cartier Watches</a></b></h3> reliable and fine <h4><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watch</a></b></h4>
정휘형
2007.05.18 13:54
아..감사합니다^^,..아는 척해야지^^..
emoticon_025
아..감사합니다^^,..아는 척해야지^^.. emoticon_025
지혜☆
2007.05.16 16:02
RGB는 3가지로 혼합이구.. CMYK는 4가지 혼합..
RGB를 CMYK로 변환시키면 3색을 4색으로 분리하기땜에
소수점이 생기지요... 반대의 경우 역시....
RGB는 3가지로 혼합이구.. CMYK는 4가지 혼합.. RGB를 CMYK로 변환시키면 3색을 4색으로 분리하기땜에 소수점이 생기지요... 반대의 경우 역시....
Molra^^
2007.05.16 14:06
혹시 일러스트로 RGB포맷의 그림을 불러들였는지요.
일러스트 상단의 File메뉴의 Document Color Mode에서 RGB말고 CMYK칼라를 선택해보세요. 그러면 될듯....
혹시 일러스트로 RGB포맷의 그림을 불러들였는지요. 일러스트 상단의 File메뉴의 Document Color Mode에서 RGB말고 CMYK칼라를 선택해보세요. 그러면 될듯....
emoticon_025
