인터넷 브라우저가 왜 이렇게 되는지요?
박현정
인터넷
3,684
2006.07.12 09:29
인터넷 브라우저가 왜 이렇게 될까요?...
해결방법 좀 알려주세요...
replica tiffany
2010.04.10 11:45
nse of <h2><b><a href="
http://www.ebestwatch.com/products/iwc-629.html"
>IWC Big Pilots IWC-74-492 imitation</a></b></h2> buying such an expensive <h3><b><a href="
http://www.ebestwatch.com/products/breitling-47.html"
>Breitling Navitimer Quartz Chronograph BREIT-200-206 imitation</a></b></h3> item, then the best <h4><b><a href="
http://www.ebestwatch.com/products/cartier-1061.html"
>exact replica Cartier Baignore Quartz CART-154-339</a></b></h4> option for you is to buy a replica watch. Duetheir high <h2><b><a href="
http://www.ereplical.com/products/chloe-bag-c210-01-3446-bags.html"
>Chloe bag -C210-01-3446</a></b></h2> quality, craftsmanship and exact <h3><b><a href="
http://www.ereplical.com/products/gucci-tote-chocolate-g162913-02-2206-bags.html"
>Gucci tote-Chocolate G162913-02-2206</a></b></h3> function, Replica Rolex watches <h4><b><a href="
http://www.ereplical.com"
>replica handbags</a></b></h4> are seen far away, when asked by <h2><b><a href="
http://www.exactreplicas.net"
>exact replica</a></b></h2> fans around the world. <h3><b><a href="
>exact rolex replica</a></b></h3> But it is obvious <h4><b><a href="
>exact Breitling replicas</a></b></h4> that the objectives Tag Heuer in particular its wealthy customers. <h2><b><a href="
http://www.bestswissreplicas.com/replica-rado-watches-swiss.html"
>Rado</a></b></h2> For those who have <h3><b><a href="
http://www.bestswissreplicas.com"
>best swiss</a></b></h3> limited resources, it is <h4><b><a href="
>cheap swiss rolex</a></b></h4> difficult to reach a piece of clock rates highly original <h2><b><a href="
http://www.bestwatchesreplica.com"
>best watches replica</a></b></h2> Heuer. The industry of <h3><b><a href="
http://www.bestwatchesreplica.com/products/bvlgari-b-zero1-30mm-bvlg-57-223-watch-replica.html"
>cheap Bvlgari B.zero1 30mm BVLG-57-223 watch replica</a></b></h3> replica watches only the <h4><b><a href="
>watch replica</a></b></h4> problem solved. Rolex Air King watches are <h2><b><a href="
http://www.handbagdesigner.net/ysl-handbags-designer-replica-handbags"
>YSL</a></b></h2> exact copies of faithClocks <h3><b><a href="
http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags"
>Gucci handbag</a></b></h3> in all directions. The <h4><b><a href="
http://www.handbagdesigner.net/dior-handbags-designer-replica-handbags"
>Dior</a></b></h4> craftsmen who manufacture these replicas k
nse of <h2><b><a href="http://www.ebestwatch.com/products/iwc-629.html">IWC Big Pilots IWC-74-492 imitation</a></b></h2> buying such an expensive <h3><b><a href="http://www.ebestwatch.com/products/breitling-47.html">Breitling Navitimer Quartz Chronograph BREIT-200-206 imitation</a></b></h3> item, then the best <h4><b><a href="http://www.ebestwatch.com/products/cartier-1061.html">exact replica Cartier Baignore Quartz CART-154-339</a></b></h4> option for you is to buy a replica watch. Duetheir high <h2><b><a href="http://www.ereplical.com/products/chloe-bag-c210-01-3446-bags.html">Chloe bag -C210-01-3446</a></b></h2> quality, craftsmanship and exact <h3><b><a href="http://www.ereplical.com/products/gucci-tote-chocolate-g162913-02-2206-bags.html">Gucci tote-Chocolate G162913-02-2206</a></b></h3> function, Replica Rolex watches <h4><b><a href="http://www.ereplical.com">replica handbags</a></b></h4> are seen far away, when asked by <h2><b><a href="http://www.exactreplicas.net">exact replica</a></b></h2> fans around the world. <h3><b><a href="http://www.exactreplicas.net">exact rolex replica</a></b></h3> But it is obvious <h4><b><a href="http://www.exactreplicas.net">exact Breitling replicas</a></b></h4> that the objectives Tag Heuer in particular its wealthy customers. <h2><b><a href="http://www.bestswissreplicas.com/replica-rado-watches-swiss.html">Rado</a></b></h2> For those who have <h3><b><a href="http://www.bestswissreplicas.com">best swiss</a></b></h3> limited resources, it is <h4><b><a href="http://www.bestswissreplicas.com">cheap swiss rolex</a></b></h4> difficult to reach a piece of clock rates highly original <h2><b><a href="http://www.bestwatchesreplica.com">best watches replica</a></b></h2> Heuer. The industry of <h3><b><a href="http://www.bestwatchesreplica.com/products/bvlgari-b-zero1-30mm-bvlg-57-223-watch-replica.html">cheap Bvlgari B.zero1 30mm BVLG-57-223 watch replica</a></b></h3> replica watches only the <h4><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h4> problem solved. Rolex Air King watches are <h2><b><a href="http://www.handbagdesigner.net/ysl-handbags-designer-replica-handbags">YSL</a></b></h2> exact copies of faithClocks <h3><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags">Gucci handbag</a></b></h3> in all directions. The <h4><b><a href="http://www.handbagdesigner.net/dior-handbags-designer-replica-handbags">Dior</a></b></h4> craftsmen who manufacture these replicas k
홈페이지 디쟈너들도 그렇고(기본적 html), 프로그래머들이
익스프로러, 넷스케이프 등 각 브라우져에 대응을 하고,
운영체제(ibm,mac) 등에도 대응을 하게 프로그래밍 해야 하는데,
귀찮거나 무지하여 익스프로러, IBM(windows)에만 기준을 두고
만들다 보니 이런 현상이 생기는것입니다. 헉 헉~~emoticon_101
홈페이지 디쟈너들도 그렇고(기본적 html), 프로그래머들이 익스프로러, 넷스케이프 등 각 브라우져에 대응을 하고, 운영체제(ibm,mac) 등에도 대응을 하게 프로그래밍 해야 하는데, 귀찮거나 무지하여 익스프로러, IBM(windows)에만 기준을 두고 만들다 보니 이런 현상이 생기는것입니다. 헉 헉~~emoticon_101
elcaa
2006.07.12 09:58
안타깝지만 해결방법이 없네여. 네이버나 다음측의 컨텐츠 쪽에서 브라우져의 폼을 맥을 지원해 주지 않는한..
